go
reidweber
since ‎2017-11-22
‎2026-07-03
User Statistics
  • 64 Posts
  • 1 Solutions
  • 10 Likes given
  • 15 Likes received
User activity
Hello, I'm trying to display different zone tag information on different plan views. For example I have floor finish information on the floor plan but in a reflected ceiling plan, I still want to display the room name but without the floor finish information. Is this possibl...
Hello, how can I edit the original JPEG file from an Archicad Library - I understand how to add custom JPEG image textures to create a surface outside of Archicad but I'd like to edit an image from the Archicad library (by changing the color of it). Is it possible to access ...
Hello, For expanses of glass walls, I'll use the curtain wall tool. In an elevation, I will dimension the overall wall height and then in a separate string, dimensions the muntin and mull sizes. The dimensions do not update with the curtain wall if changes are made (like the...
Hello, I am having issues with the wall assembly displaying correctly in relation to another wall and the site grade, modeled as a slab in the section view. In this example, the concrete footing should be in the foreground of both the earth "slab" and the framed wall above i...
Hello, I recently upgraded to Archicad 26. Originally, I accidently downloaded the INT version of Archicad instead of the USA and was working in that file for about a week. I then realized the error and downloaded the USA version and opened the file. I'm now finding that non...
