SOLVED!
Organising palletes
Bara3
Hello, is there a way I can make smaller the pallete that is at the bottom of the screen?
When I use smaller screen I do not see all options and I do not know how to move within the pallete to see all of them. I have already tried to search through the Palletes and Toolbars, but I did not find this specific one. I would like to have there just icons or move to see all of the options.
1 ACCEPTED SOLUTION
Solution
Hi @Bara3 , there’s no way to change the quick options bar into only icons but you can replace it with quick options palette like this :
AC 28 INT 3110/WIN 11
3 REPLIES 3
Solution
Thank you, it will work perfectly.
And, if you use the Quick Options Palette, then you can use the "Window> Hide Quick Options Bar" menu command to hide the Quick Options Bar from the bottom if you do not use it anyway.
