Output scale 3/32" = 1'-0"
We are working on a project with a large footprint. All of our overall floorplans are at 3/32" = 1'-0". Since this is a "custom" scale according to AC, the output scale in Plotmaker displays 1:128. Short of having to type in all of the scales on all of the sheets individually or creating a new master sheet just for that scale, is there a way to make it display correctly or is it wishful thinking?
4 REPLIES 4
Link
Wishful thinking, but you're not the only one!
For now, you will have to input the scale manually.
Link.
Is it already on the wishlist or should I add it?
I ended up just adding a Title Type just for that scale, which wasn't a big deal, but work around is work around.
TomWaltz
We've got a GDL object that we use for drawing titles, that has a function in it to catch Architectural scales that Archicad does not recognize.
Tom Waltz
