christiandcdc
PDF Publishing Saves to Wrong Size
Publishing to PDF defaults to 8.5 x 11 regardless of the layout size. Specifically, my layouts are 24x36 and has been working perfectly for 2 years and now all the saved files are 8.5 x 11 portrait.
Additionally, when I print a PDF from the dialog box, with the page set up at 24x36, the saved PDF is 8.5x11 portrait.
I am OSX Leopard, AC10, and have Acrobat 8 and Acrobat 7.1 Pro.
Any thoughts???
MacBook Pro
Mac OS X Lion 10.12.4
2.5 GHz Intel Core i7
16 GB RAM
AC 20 USA
3 Replies 3
christiandcdc
Other projects publish to PDF correctly, so there must be a setting I am missing???!!
MacBook Pro
16 GB RAM
AC 20 USA
Erich
Assuming you are using the internal PDF functions, check your paper handling setup in the print dialogue before you send to the PDF. The attached image shows this in Tiger, I don't have Lepoard yet.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
christiandcdc
I finally got the print to PDF to work by NOT using the OSX PDF function (I used the PDF 7 print driver), but it is sure annoying to individually print 50+sheets.
Erich, thanks for the tip ... Leopard is slightly different, but that didn't seem to be me my problem.
Still no luck in the publish function ....
MacBook Pro
16 GB RAM
AC 20 USA
