2008-05-20 08:18 AM - last edited on 2023-05-19 04:02 PM by Gordana Radonic
2008-05-20 10:41 AM
Adam wrote:Nope. The issue might be unrelated, but a guess is that your pdfs are imported and treated as bit-mapped pictures?
Anyone have a explanation why a layout that has two imported PDF files (total size 100kb, all text) should, after publishing (to PDF) turn into a 5mb monster?
2008-05-20 06:43 PM
2008-05-20 06:55 PM
2008-05-20 07:09 PM
Karl wrote:correct - there is a title block on the master and on the layout 5 placed PDF pages, 4 from one file (25kb) and 1 from another(75kb).
Just to make sure I'm understanding: there are no drawings of any kind on the layout (or Master) - only the text PDF files that originally were 100 kb?
Thanks,
2008-05-20 08:40 PM
Adam wrote:You might have found a bug. Test what happens if you just place one of those pdfs on an empty floor plan, and print that to PDF. Then report the issue to GS through your reseller, and supply the files.
2008-05-20 09:06 PM
2008-05-20 09:13 PM
2008-05-20 09:13 PM
Adam wrote:OK. But please add your ACversion, platform, machine info in your signature! Are you using AC11? On what system?
Interesting.....placed the PDF on an empty floor plan - same result. I then changed the font to Arial and ended up with a 1.91mb PDF. Times New Roman = 2.5mb PDF.
Still bigger than they should be but at least points to the problem. Thanks for your help - I'll report the issue.
Adam
2008-05-20 09:15 PM
