2004-01-08
04:34 AM
2025-01-29
05:27 PM
Aruzhan Hamar
2004-01-08 07:09 AM
2004-01-08 03:42 PM
Link wrote:I'll have you know one of the Spice girls was just on the new Absolutely Fabulous (at least my daughter said it was her)...so....it's not over yet
It's got to be a direct link to the model, via navigator views. Sure the files are bigger, but then so is a decent computer![]()
The trick is to create a pre-linked template system, so that you don't have to repeat the procedure all the time. I haven't personally used a ~traditional~ pmk for over a year and never encourage it in my training. That method is going the way of the single-fin surfboard and the spice girls![]()
Just my opinion!
Good luck.
Link.
2004-01-08 06:27 PM
2004-01-08 06:51 PM
2004-01-08 10:11 PM
2004-01-12 11:23 PM
2004-01-14 04:17 AM
Adalbert wrote:Once a viewset is created it can be published as a pmk- hence no naming problems.
In pre 8 each pmk had a unique name. Using the publisher this is not impossible but very difficult requiring lots of nasty text input. The result could be lots of pmk’s with the same name.
IGS should to tell us wish direction is the development going.
What is the repercussion of linked pln when opening the project on a different machine or platform?
2004-01-14 03:01 PM
Adalbert wrote:Do you have Quickeys? You can make a "tool bar" with all your normal quick views titles so all you have to do is save the appropriate text in Quickeys, save the quick view....click the appropriate Quickey button on the Quickey tool bar (opened from the menu bar), and you have it named without typing anything. I am re-quickviewing all my old plans (but continuously used), and it is very quick and easy by having Quickeys. No text input is needed, except once.
2004-01-16 01:09 AM
