PM 8.1 printing problem
Since I upgrade to AC8.1 I have to set the print parameters in the same file every time I open it. (Pint-Print Options-Scale all to ??-Shrinks oversize Layouts to Page) What change?
1 REPLY 1
Use PlotMaker Publisher to set and save printing preferences.
After creating a new view set, drag your layouts into the set from your project map. You will have to set printing preferences one-by-one...
Don't forget to save your settings...if you close without choosing save settings and close...the view set will be lost...
