ā2003-11-07
01:24 AM
ā2023-05-19
04:08 PM
Gordana Radonic
ā2003-11-11 05:41 PM
Djordje wrote:I am actually "plotting" not "printing". Do you mean plottting? I did as specified in the "Plot Options" see attachment. The output is still 1/4" from the bottom & 1 3/4" from the top.
You are not using Device margins; set the Master to the Device margins, and when printing...
Djordje wrote:So why is there an option for "Use Margins of Master Layout"?
... ALWAYS set the margins to the Device margins.
ā2003-11-11 05:46 PM
ā2003-11-11 05:52 PM
ā2003-11-12 08:24 PM
ā2003-11-12 08:42 PM
ā2003-11-12 08:47 PM
ā2003-11-22 07:56 AM
ā2003-11-22 01:02 PM
Hari wrote:Are you sure that you set your device margins as the relevant ones?
There is lots of unused paper around the drawing larger than the set margins. HP 755 ps
ā2003-11-22 07:09 PM
ā2003-11-26 02:11 PM
Djordje wrote:djordje, i have just found an instance where the settings of the device margins are not necessarily desirable:
You are not using Device margins; set the Master to the Device margins, and when printing, ALWAYS set the margins to the Device margins.
