Pallet with drawing and layout
I found a pallet that sits below the main pallet that indicates the drawing and layout. But as my archicad does not record the personal profile I lost the pallet.
Where do I activate this pallet?
5 Replies 5
Hi, I don't know to which palette exactly you refer to, but palettes can be activated in window>palettes or in case is a toolbar can be found in window>toolbar. I'll activate them all one by one until find it, and if you can't find it there try activating toolbars too.
BTW add what Archicad version you are using and OS, to get better and more precise answers to your questions.
It's not a pallet it is a bar...
Which AC version are you using?
Do you refer to the Bar shown in the image?
if yes it is activated in the window menu it's called Tab Bar, if not every bar, toolbar, or pallete can be activate in the Window Menu, try finding it there, and when you get your answer please let others know.
Yes t was a tab bar.
Finally I discover. My Window Menu didn't have the show/hide tab bar. So I put the item in the Work Environment and save the scheme of command layouts.
I have the AC19 and Windows 10.
Good to hear that you find a solution.
