Partial Screening
I am working on a project which will have phases for future developments. I would like to show the phase of the development the will be built later in screened (lighter) mode. I tried overlaying two duplicate drawings with different pen sets on the Layout sheet with the top one partially covering the one below. When plotted I could not see the difference. I realized the reason being I had to choice of Plot with Color or Grayscale or Black & White selection only. Is there any another way around this?
AC10 on PowerBook with OS10
HP Design Jet
Laura Yanoviak
Really? We do this all the time. You should be using a "black" pen set and a "gray" penset -- try printing (not plotting).
Laura:
I did not have to try Print instead. In the Dwg. Selection Setting I chose "Screened Pens" under Pen Set instead of "Grayscale Pens" under Color.
It worked.
Thanks for your response.
