svpribyl
Pen color of Stair in Layout is Incorrect
I have a simple stair made with the stair tool. I set the pen color parameters. All is good in plan view. However, in the layout, the pen color of the nosings is incorrect. I use one pen set for everything, so it's not a matter of having the layout using a different pen set.
Any help would be appreciated.
Thanks!
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
6 Replies 6
So just to be sure check the settings of your drawing in the layout.
The pen set should be set to "By View..." or the correct specific pen set is chosen, and the colours are set to "Defined By Pen Set.
svpribyl
Hi Barry,
Here are my settings.
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
OK then, so long as you are viewing the plan with the "General" pen set they should both be the same.
If you are using the same plan view from the view map that you have placed on the layout then that pen set will be chosen automatically.
If you are viewing the plan from the Project Map then you manually have to set the pen set.
Select the drawing in the layout and then choose 'Open Source View'.
This should match your layout exactly.
If not I am not quite sure what is happening.
sinceV6
Hi.
Could be related to this thread, first post.
Best regards
svpribyl
SinceV6,
You are correct. I found a parameter (nosing line pen) that was set to the pen color that is showing up in the layout, even though it does not show up in the 2d view.
Thanks!
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
svpribyl wrote:
SinceV6,
Thanks!
That is strange.
The layout should be showing what is in the 2D view.
If the same pen set is used in the 2D view and the layout drawing there should be no difference - at least that is the way I understand how it should work.
