Bling Keeta
Place Unlinked Marker
"Place unlinked marker " always greyed out. Is there anything I missed.
Ben Ling
B.L.LING ARCHITECT INC.
Vancouver, BC, Canada
Mac Pro 3.5 GHz 6-Core Intel Xeon E5
AC 20
6 Replies 6
I think the problem is that you have the name of a Viewpoint in the Reference To field so ArchiCAD assumes you want to link the Marker to that.
Can you delete that field?
If there is nothing in that field, the unlinked option should be enabled.
Bling Keeta
It didn't work. Reference to field is now blank, but I still can't do "Place unlinked marker. Any other suggestions? Thanks.
Ben Ling
AC 20
I have no idea.
Works perfectly for me.
If you start a new file using the Template, does it work there.
If yes, then it may be file related.
Scott Bulmer
The same holds true for me as well. I have New & Reset All a new PLN and cannot place an unlinked marker into any viewport. Any progress on a solution? Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
I just double checked. No problems here.
Scott Bulmer
Thanks Matthew for checking this for me; I am at a loss. It would be really nice to be able to place unlinked markers, but it is simply not available on my system for some reason. This is the case for both AC14 & 15.
Thanks again, Scott
