Placing drawings on layouts
Archizone
Since yesterday June 5, 2023 I can no longer place drawings in layouts with Archicad versions earlier than 26. The files to be placed (jpg, png, pdf, etc.) show as ghosted when browsed. For some projects I want to continue working in earlier versions. Does this have anything to do with having been asked to sign in to my SSA account before opening an Archicad file?
7 REPLIES 7
I shouldn't think so.
Can you show a screen shot of you trying to browse for the files - showing them ghosted?
Looks like it could be a file permissions error, do you have access to view / edit these files?
Have you had any OS updates? If so do you need to update permissions/ security for Archicad?
or
is the layer that the drawings/ figures are to be placed on locked?
Regards,
Scott
MSI Creator ZP16, i7-12700H, 32GB RAM, RTX 3070 8GB
Archizone
When I was requested to sign in with my SSA password I was told that certain Archicad features (like placing a drawing perhaps?) would not be available until I did within then next 8 days. This request never occurred before.
Archizone:
In your screen shot, near the bottom of the dialog box, change the Enable option from ARCHICAD Solo Project to All Available Types.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX11.7.10
@Archizone ,
I think you will find David has the solution for you.
Archizone
Yes! Enable All available Types did it. Thank you very much.
