Placing renders in layouts??
its a newbie question but i haven't found the workflow yet. How can i store renders internally and place them on layouts?
Also if the model changes i have to go to each saved render and re-render each one?
Stress Co_
Save a 3D View like you would save any view.
From the Project map, select the Generic Perspective from the 3D heading
(I'm assuming it's a perspective view).
Be sure to set "Generate in:" to Photorendering Window.
Place the saved view (from the View map) to a layout.
The view can be set to manually or automatically update on the layout.
Make sense?
Marc Corney, Architect
Red Canoe Architecture, P. A.
4 REPLIES 4
Stress Co_
Make sense?
Lingwisyer
Guru
Pretty sure it will re-render every time you go to that layout, so you should probably set it to manually update.
Ling.
Thanks! I will try that! Because I was running out of time I just saved the renders to disk and then drag n drop them to my layout.
Lingwisyer
Guru
It is probably better to do this then saving it internally as then you have access to the renders for other documents, post work and such.
Ling.
