PlotMaker R2 Error
In the graphic below, the top half shows a screen shot of a PlotMaker layout in 8.1 R1. I then loaded R2 build 2256. The lower half of the graphic shows the results -- extraneous lines on the floor plan. Moving to different machines verifies that R2 is causing the problem. The machines with R1 display it correctly, the machines with R2 do not. Sending the layout to the plotter yields exactly what you see in the preview. Burned again!
0 Replies 0
