‎2003-10-30
07:37 PM
‎2023-05-26
12:09 AM
Gordana Radonic
‎2003-10-30 08:00 PM
‎2003-10-31 05:07 PM
Can anyone help? or at least sympathize?It's all about the paths to the libraries. We have all our hard drives named identically for this very reason. It's not so much a concern with stand-alone PLNs as when you open the file and set the correct path for the library and then save, BGArchiCAD gets the new library path. You get your network libraries o.k. because that path is consistent across all machines.
‎2003-11-05 03:21 PM
‎2003-11-05 03:34 PM
Katie wrote:Nope. it's the same with 8.1. You can read my previous post as to the cause of the problem. To fix will require a bit of a change to the BGArchiCAD startup routine. A needed one mind you, but it might take a while.
to hear if this issue is fixed in 8.1 ...
‎2003-11-05 03:59 PM
‎2003-11-05 08:46 PM
Katie wrote:You should have taken on v3, but bear out until 8.1 arrives ...
we havn't received the 8.1 discs yet, and we're still discovering things that 8 does every day (we spent a long time sticking with 6.5 until v2 came around).
‎2003-11-05 09:47 PM
‎2003-11-06 10:52 AM
Djordje wrote:hmmm. library loading activity is still not quite up to the job on a mac as it should be in 8.1 either.
‎2003-11-06 04:12 PM
