2005-04-01
11:50 PM
2023-05-30
03:27 PM
Rubia Torres
2005-04-02 02:45 AM
2005-04-04 04:33 PM
rongyu wrote:Are these newly imported views, or ones you are updating. Check "fit frame to drawing" under drawing settings.
In plotmaker 9, on the top & left ends, the dimensions don't show properly. Every time, I have to stretch the frame to show the dimensions. Is there any trick to do it properly without stretching the frame?
Thanks.
2005-04-04 06:21 PM
rongyu wrote:If you want the view to be right every time you bring it into plotmaker. Make sure that you save "Current zoom" when you are creating/defining your views in ArchiCAD
Thanks.
