We value your input!
Plotmaker 9 dimension problem
In plotmaker 9, on the top & left ends, the dimensions don't show properly. Every time, I have to stretch the frame to show the dimensions. Is there any trick to do it properly without stretching the frame?
Thanks.
I haven't noticed this. What platform, OS?
Thanks.
Are these newly imported views, or ones you are updating. Check "fit frame to drawing" under drawing settings.
Ben Odonnell
Thanks.
If you want the view to be right every time you bring it into plotmaker. Make sure that you save "Current zoom" when you are creating/defining your views in ArchiCAD
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
