Plotmaker Master Layouts
Vitruvius
Is there a way to delete unwanted master layouts?
The little toggle at the top right of the Navigator window won't allow it, nor does hitting the Delete key.
Cameron Hestler, Architect
Archicad 27 / Mac Studio M1 Max - 32 GB / LG24" Monitors / 14.5 Sonoma
4 REPLIES 4
Sounds like the master sheets you are trying to delete are in use. Change the sort method in the navigator to by master and you can see which layouts are still using the old masters and change them. Then you can delete the unwanted master sheets.
Vitruvius
Actually I'd already tried that - which is what is so perplexing. Any other suggestions?
a master layout that is set as the default will not delete either...
Aussie John
Also if a layout haas a master applied - that one cant be deleted either
Cheers John
[/size]
