2004-02-09
		09:54 AM
		2023-05-19
		10:27 PM
			Gordana Radonic
2004-02-13 12:12 AM
2004-02-13 06:03 AM
Weston wrote:Absolutely helps. I've wondered about this very issue, but never bothered to check the manual. Thanks!
Also OSX help mentioned that if you "Preview" the image from the print dialog and then print the image from the preview window, you will lose resolution quality since you are essentially making a pdf from the pdf OSX created to show you the preview.
Any of those tips help?
Wes
2004-02-13 11:27 PM
Vitruvius wrote:point taken, vitruvius. point taken!
BTW Ben - 5 cups o' java and skiing don't mix - you don't want to be drilling through 4 layers of clothing to answer nature's call at 8000 ft.....
2004-02-13 11:34 PM
2004-02-21 06:56 PM
2004-02-21 09:16 PM
Burginger wrote:I assume you use this for online viewing only--I can only imagine how many ink cartridges would be necessary for a set of prints.
Recently I tried an export of a PDF from Plotmaker, then I loaded it into Adobe Illustrator, changed all lines to WHITE and then placed a dark blue square behind all the drawing elements, saved it again as a PDF, and created the old fashioned BLUELINE effect.
2004-02-25 05:08 PM
2004-02-25 06:19 PM
htra wrote:Too bad...On a Mac you can save to PDF directly from the print dialog box. Until we can publish to PDF, we're limited to a drawing at a time, but no other software is necessary. Sorry, but can't help on the PC side.
I would like to be able to make PDF files of ArchiCAD files. What's the best way to do this? I'm confused about which Adobe product I need, and I've read with interest the discussion about making PDF's from Plotmaker, which is exactly what I would like to do.
Right now I'm running ArchiCAD on both Apple and PC, but am switching to PC only pretty soon if that makes a difference.
2004-02-25 10:13 PM
Dave wrote:There is a great freeware program called Combine PDF http://www.monkeybreadsoftware.de/ It does what is says. I use it to quickly and cheaplyhtra wrote:
2004-02-25 10:18 PM
Dave wrote:David I dont understand that. Print to PDF and all the drawings (after selecting plotmaker options) will be "printed" in one file.
