2004-02-09
09:54 AM
2023-05-19
10:27 PM
Gordana Radonic
2004-02-25 10:36 PM
Aussie wrote:Well, how about that... another senior moment. I actually think I have done that, and it works... so disregard my first contribution to this thread. I'll keep quite.Dave wrote:David I dont understand that. Print to PDF and all the drawings (after selecting plotmaker options) will be "printed" in one file.
Until we can publish to PDF, we're limited to a drawing at a time
…or did you mean directly from Archicad
2004-02-25 10:42 PM
Aussie wrote:Right...Sorry about that. I was responding to posts last night during the slowdown and guess I forgot we were discussing PM between the time I read the original post and composed mine.Dave wrote:David I dont understand that. Print to PDF and all the drawings (after selecting plotmaker options) will be "printed" in one file.
2004-02-26 05:22 PM
2004-02-26 05:51 PM
htra wrote:When you PRINT (not PLOT), there is a button that allows you to save the file as PDF. It is wired into the OS--nothing to do with Adobe.---- I just realized, your computer info is not in your signature--you must be using OS X to have this capability.
"Too bad...On a Mac you can save to PDF directly from the print dialog box. Until we can publish to PDF, we're limited to a drawing at a time, but no other software is necessary. Sorry, but can't help on the PC side."
I'm assuming this is from an Adobe program at this point? I see "PostScript Layout File" from Plotmaker (which I do use to drop drawings into emails with) but does this have anything to do with an Adobe product?
2004-02-27 02:49 PM
htra wrote:
I would like to be able to make PDF files of ArchiCAD files. What's the best way to do this? I'm confused about which Adobe product I need, and I've read with interest the discussion about making PDF's from Plotmaker, which is exactly what I would like to do.
2004-03-01 06:57 AM
gkmethy wrote:And just to be clear... If you PUBLISH you will end up with INDIVIDUAL PDF files. If you simply choose the appropriate sheets and hit the PRINT button and choose "PRINT...Selected in Navigator Window" or Print ENTIRE Layout Book... You will indeed get ONE file with all the sheets....
On PC you don't need any Adobe product. ArchiCAD 8/8.1 comes with Amyuni printer driver, which is a PDF converter. You can set up a print set in Plotmaker/ArchiCAD publisher to send your drawings to Amyuni, and they will be saved as PDF.
2004-04-25 07:08 PM
2004-06-22 03:43 AM
Matthew wrote:Mattthew,
I (we) have been using PDF on the Mac for years with no problems with output quality.
2004-06-22 04:24 AM
2004-06-22 04:59 AM
