‎2005-01-25
12:48 AM
‎2023-05-26
12:15 AM
Gordana Radonic
‎2005-01-25 01:54 AM
‎2005-01-25 01:46 PM
‎2005-01-25 03:52 PM
‎2006-01-05 07:06 PM
Link wrote:I did do this with some success until I realized that elements of the image that have a value less than black are not printing. When the image is imported as a "picture" in PM, it prints correctly. When the same image is cut>paste onto the layout, it appears correctly on screen, but any graytones do not print. I've tried experimenting with different image resolutions to no avail.
One workaround that ~may~ work is to double click on the image in PM, and in the window that appears, select your image a copy it to the clipboard (ctrl/cmd +C), then close the window, delete your original image and paste the copy back in.
‎2006-04-14 11:10 PM
‎2006-04-25 06:25 PM
Andre wrote:Another option to check is by rightclicking the viewport in Autocad and select the option to show image. If I'm not mistaken, even if the image is not showing in Autocads viewport, it should still print (it's seems to be some setting to save system resources in not having to reload images).
...The problem is that I can't get these to show when I save drawings as dwg files using Publisher...
