Plotting a PICT / Image file
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2004-04-30
02:26 PM
- last edited on
2025-02-10
04:39 PM
by
Aruzhan Ilaikova
Can anyone shed light on the plotting of a pict file. They seem to print fine, but plotting leaves an empty space.
I am using the most up to date version of ArchiCAD on OS x Panther and do all my plotting through ArchiCAD. I have tried merging the file in various guises directly, and via Plotmaker, but the merge as drawing elements option simply gives me a blank square.
I seem to think it should be possible, but am up against that blank wall at present - can anyone knock a hole in it for me?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-04-30 02:53 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-04-30 02:47 PM
I once had a problem where all my images came out black and white.
I found that in plotmaker, in the plot menu tabs/ plot setup, (at the top left of your screen) my plotter model wasn't specified properly, it was set to 1050 instead of 1050C.
Could also be your plotter driver.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-04-30 02:53 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-04-30 03:42 PM
Good luck.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-04-30 03:43 PM
It seems that you can't plot pictures directly from ArchiCAD. If you import the ArchiCAD file into PlotMaker as a view you can plot the pictures.
Greg
Windows 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-04-30 04:37 PM
Can anyone else help?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-04-30 04:43 PM
Greg wrote:Hi Greg
I just had this come up this week.
Greg
Is that 'can't' definitive. I knew you can plot through Plotmaker, but I was hoping for some way to manipulate the image back to ArchiCAD in plotable form
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-05-03 05:00 PM
Towtrucker wrote:It was in ArchiCAD 7.0:Greg wrote:Hi Greg
Greg
" Read Me for Plotter Users.htm" wrote:But this line isn't in the Read Me with 8.1.
PlotMaker supports bitmap plotting on some plotter models that support the Hewlett Packard Raster Transfer Language (HP RTL). This feature is not yet implemented in ArchiCAD.
Greg
Windows 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-05-06 04:59 PM
What is the type of plotter/printer you are trying to get this image outputed on?
We also need you know your system config. You on a Mac or Windows?
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
