2024-07-11 06:00 AM
Why is Archicad printing all my lines as thin, even though I have them selected to go from 0.1 to 0.5 mm? the view setting shows on line thicknesses correctly but when I print them they are all thin. I am trying to complete a drainage plan and need thicker lines for drains, etc.
2024-07-11 06:53 AM
If you are 'publishing' to PDF then check the document options.
If you are 'printing' to PDF then check the printer options and there will be a similar hairline option.
