2012-08-2509:44 AM - last edited on 2023-05-2612:05 AM by Gordana Radonic
2012-08-2509:44 AM
When trying to print with marquee on a rotated plan the output is always wrong. It is like the marquee is misplaced every time. It is impossible to get to print the part inside the marquee.
unfortunately this is a known issue on Mac that is entered to our defect database with no. 130450.
As a workaround I recommend saving the selected part as PDF before.
I was clicking the "Preview" button. But anyway, the "Save as pdf" produces the same result. Output is rotated and is actually displaced related to the marquee.
(note: I'm working on TW)
The only workaround is to create views and place them on layouts...
yes, you are right, my selected area was too small to see the difference. Saving to PDF works only for such tiny details.
Your recommended workaround is also correct. You can either create a drawing or a detail/ worksheet that can be printed well.
