Problem with publishing a drawing
When i try to publish my drawing, using a navigator, a strange thing happens: the text that i have on the drawing is huge.
I have set a R 1:2000, at the layout, and the drawing looks ok when it is published, but the text on it, seems not to be resized with the drawing. It seems that it stayed at it`s original size (like it is at the R 1:100), as it is huge comparing to the my R 1:2000 drawing.
Where seems to be the problem? Thanks.
P.S.
I am not 100 % sure that the text only won`t resize. Maybe it is the case with the linear Dimensionig too.
Erika Epstein
Did you check whether the problem text is set to Fixed or Scaled?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
