Problems with displaying numbers in dimensions.
Here is my problem:
I set the linear dimensions and the working units to cm. Then I make a dimension line. The result is one-thousand-two-hundred-twenty-two. It is displayed as 1,222.0. How to make the comma go away, so that it is diplayed 1 222.0.
Thank you previously for your reply.
Todor Boyadzhiev
Hi Todor,
the format for numbering (for windows) that is used by he dimensions is set in the configuration panel. Under Regional and Language options you can set the format by clicking your country or customize.
Note that only new dimension get that format right away. To get this format for existing dimensions, you have to change something in the project preferences dimension settings. Only then the dimension are regenerated. You can undo that change after the regeneration.
Thank you so much
