Project Info won't stick
My "Project Info" won't permanently link to my project.
I fill out the project information, save the file as a .xls to my project library, then load it into the project. Each of my sheets neatly displays correct title block information according to the linked project info spreadsheet.
But when i next start the project, or sometimes even mid-work session, the project info will detach itself and my title blocks will revert to default status, with no information filled in.
Any ideas?
1 Reply 1
Erika Epstein
I don't typically save the project info xml into the project library but a separate location. From there I import it into the project info window.
I wonder if the file is having a tough time deciding which project info to read, the default or your imported.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
