Properties | Expression based on Renovation Status
I have set up a CONCAT expression to merge a bunch of various properties and text (for the sake of this example I'll refer to it as CONCAT-1.
I want the expression to present different information depending on the renovation status of the element.
I think what I need is an IF function, something like:
IF the element is new then show CONCAT-1,
IF the element is existing then show CONCAT-2,
IF the element is to be demolished then show CONCAT-3.
However, I am not having much luck at all with the IF function in the expressions.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
10 Replies 10
poco2013
Mentor
You can not have two expressions within the same expression sequence.
Use the ADD button to make a new expression sequence and place your second expression in it. The program will use the first expression sequence that is valid. Otherwise, all must be in the same expression.
Gerry
Windows 11 - Visual Studio 2022; ArchiCAD 27
