Publish file with hyperlinks as .dwg file
We are using Archicad 8.1 on Mac OsX - is there a way to save a plotmaker file as dwg and include the hyperlinks that are in the .pln file? When I publish as .dwg the resulting file is missing the hyperlinked info. The hyperlinks are attached in the .pln file - not bound, etc.
thanks
R
10 REPLIES 10
Eduardo Rolon
Under File - Publisher - Publish
Just drag from one window to the other, then select the files and change the format to dwg. Also remember to specify where you want them saved to under "view set publishing..."
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
