Published pdf scale is off
I have been using the Amyuni PDF Converter to publish PDF of the 24" x 36" drawings.
When the PDF is opened using the Adobe reader and printed, the scale is off by a fractions of a foot. Horizontal (x-direction) 100' actual is printed at 99'-8.5" or so. Vertical (y-direction) 80' actual is printed at 79'-10.5".
When any of you sub-out your drawings as PDF to be printed, how do you assure the scaling remains true?
7 REPLIES 7
Thomas Holm
That happens when you print the pdf with "shrink/resize to paper margins" checked in Adobe Reader's or Acrobats's print dialog. If you check "no page scaling" (or something similar, depending on Adobe version) it should print right.
I have the Reader dialog set to "None"
I can not see were the Amyuni Converter can be set up in Publisher, but if a layout is printed to the Converter from the print menu the Print layout shows the screen shot.
Well I have come full circle.
Here is a link to the same question
I just do not trust this PDF scaling.
Jay,
Your master layout should reflect the same size as the media you are printing to...therefore, Master Layout Settings>Import settings from printer>PDF Converter>Custom
Set the size in millimeters...610 x 914
Now if you print your layout to pdf, your master layout will match the print drivers margins and you can scale your pdf at 100%...
Clear as mud?
Think I got it.
I am running a test.
This can cause a little heart-ache when you set the parameters correctly and then find you have to resize the title block by 2%...and move any independent text that may be floating on your master layout...
I print everything to pdf or plt...and adapted my master layouts as such in PM3.1, with seperate plotter settings and pdf settings...
