Publisher - Possible to force lowercase file extensions?
Hi
We use a webhotel / cloud for exchange of drawings, however that system will only accept files with file extensions in lowercase. When I publish from Archicad 15 Publisher the files have uppercase extensions (.PDF instead of .pdf, for example). When publisher is so good at generating lots of drawings so quickly it is a pain to then have to go and manually change all the extensions to lowercase.
Is there a way to force Archicad to append lowercase extensions?
Alternatively does anyone know if there is a way of doing this to multiple files in OSX?
many thanks in advance
Stuart
1 Reply 1
Hi
Just found that I can use Automator to batch rename file extensions in OSX, so I will do that.
http://forums.macrumors.com/showthread.php?t=1057019
Stuart
