Publisher Problem
In AC 10, when I click on publisher and publish more than (1) PDF, the PDF file comes out in the mbs.
I recently published 6 sheets and the file sizes totalled 125 mbs. This was publishing all 6 sheets at once.
However, when I publish each sheet separately, the file size is minimal.
Any idea of how to fix this?
Thanks,
Grant
Thomas Holm
Sorry. I don't have your problem. A guess is that there is something that differs when you publish the whole set, like some display setting. Old-fashioned bit-mapped fills can blow up file size, for example. Make sure that you have everything set to vectorial.
