Total number of sheets in Layout editable?
We have a cover sheet that we include in our set that contains mainly just rendering views. I don't want this sheet included in the total count of sheets in the set. this doesn't seem possible in Layouts. am I missing something or is this really not possible? If not, it woud be nice to get something simple like this to be rectified.
AC USv10, build 1010
4 Replies 4
Chris,
Just select the layout you don't want included and select the settings and check the "Do not include this layout in ID sequence" See attached. I think this is what you are looking for.
Gerald
Gerald Hoffman
Archicad 4.55 - 29-Latest USA
I was thinking that too, Gerald, but on further contemplation decided Chris wants the Number of Layouts (eg for "Sheet X of Y") autotext to not consider the cover as part of "Y".
Link
And we all know that can't be done.
Not within the same file anyway.
Link.
Thanks guys, that's what I was after, the "Sheet x of y". I understand how to turn it off as a layout. My need is simpler than the others given, but this seems like an easy enough fix. I hope it's on GS list.
