Publishing PMKs Causes Display Issue
I've encountered a persistent issue when publishing PMKs. Not a biggie just a tad annoying.
After the publishing process completes, the view unexpectedly jumps, appearing either more zoomed in or out than it was initially. This shift in view isn't just a visual glitch; it also affects interaction with the elements afterwards. Trying to select any element becomes problematic, as the selection doesn't respond, followed by another view jump. It's as if the displayed elements are not aligned with their actual positions.
Has anyone experienced similar issues or have insights on potential fixes?
Not a great demo below, but hopefully shows the issue.
It's perhaps not obvious in the GIF but after the publish, when the cursor flashes red as I attempt to click the green line/grid, the selection doesn't occur and after a moment the view/zoom jumps.
Operating system used: Windows 10
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
0 Replies 0
