Radius in verticle wall?
I have a 8 inch thick, 6 foot long, verticle brick wall that is 5 foot high on the left and 3 foot high on the right. Instead of a straight line from left to right, I want an inverted arch to give a nice sweeping look to the wall. A wrought-iron gate (3 feet wide) will be between the the exact mirrored wall on the opposite side of the gate to make a total length structure of approx. 15.
The question... how do I make the inverted arch (radius?) in the verticle wall. Thank you for your help.... Doug
5 Replies 5
Dwight
Round Wall Hole - Window Opening. When placing the window opening into the wall you might get a warning about it extending beyond the wall. That is what you want.....
Dwight Atkinson
Dwight.... thanks for the reply. I did that to get the desired look... but how do I then get rid of the window? I changed the window material to brick (as my wall is), but how do I get rid of the window frame that extends above the vertical wall?
"Round window opening"... Emphasis on the word "Opening"! But, it gives me a square opening, not round even though I am using the "W Round Fixed" in Specialitie Windows.
Thanks..
Dwight
I apoplogise. I am an idiot.
In my library I tweaked the code and forgot.
Graphisoft made a square WALLHOLE and plugged it....
Dang..
In your case, I would change my advice:
Try a Solid Element Operation with a swooping roof or a big cylinder.
Dwight Atkinson
Dwight
That word apopologise - it is a cross between apoplectic and apologise. Perfect.
Dwight Atkinson
