Re: Archicad 23 - Wall Intersection
I am having a problem with getting the linework to be consistent when connecting walls (in plan) as per the attached image. I have looked through all the settings related to graphic overrides, intersection priorties, renovation filters, etc. and I am at a loss as to why this is happening.
any advise to resolve this issue would be greatly appreciated. Cheers.
4 REPLIES 4
Have a look at your wall composite settings, and make sure you have the end lines turned on.
Hi Barry,
Yes the boxes are ticked. It appears to be only with the wall composites as I tried a standard block wall using the basic option and the linework works fine. A mystery.
Chris
Are you 100% sure you checked the correct composite?
Right click on the wall and choose 'Edit selected composite'.
Barry
It might be that your "Skin End Line" is a different pen from your contour line in the composite.
It's not very clear in the Composite settings what do these Pens control and I've seen it before that people confuse "Skin End Lines" with "Separator Lines".
