Rebuilding sheets in Plotmaker.
Is there a setting, preference, or option that takes you to a new sheet when you double click on it in the subset tree? I used to navigate that way, something has changed, now nothing changes and I don't see the sheet until I hit rebuild.
Works fine for me.
It used to work fine for me too, now it doesn't. How do I get back to the fine world?
never seen this before, but try deleting the plotmaker preference files. Say what OS you're using and I'm sure someone can guide you to where they are if you dont already know...
HTH
Wes
