Reconstruction status in the module
Hello.
I place engineering communications in the project through the module. In the source file with communications, I change the status of reconstruction of objects. In a composite project, no changes are made to the status of module elements. Is it the way it should be or have I not figured out something?
P.S.
https://salegabriel.com/fr/
Hello puwiliso,
It is necessary to match the attributes of elements between the module and the host file. Do you should check this out ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
