2017-06-16
04:26 AM
- last edited
2 weeks ago
Aruzhan Ilaikova
2017-06-16 01:30 PM
2017-06-16 03:01 PM
2017-06-16 05:35 PM
AWilson wrote:Hi AWilson, did you saw the Archicad Training? If not I will recommend that you see them and learn from them, If you are used to others software you will try to make Archicad work the same way as others. Archicad works a little different than others, but when you learn you will see that is easy, make sense and is intuitive.
There is no "standard"! I'm a one person show. I've been learning ArchiCAD on my own which has not been easy. I'm on ArchiCAD Solo 20 on PC. Whatever I create is becoming the standard IF I can figure it out. What you just said to do is completely foreign to me so I'll see if I can do it. Usually there's always some tiny basic command I don't know or understand and ArchiCAD fails to go over those tiny basics and I look for hours trying to find what I need to no avail. I'll be back on to share if I can or cannot get this done.
