Reflected ceiling plan of sloping soffit
Hi
I'd appreciate some help on how to created a reflected ceiling plan of a sloping soffit. I've not done any RCP's in Archicad yet and what I would also like to generate are plans of the sloping soffit looking square on in order to create cutting layouts.
Thanks in advance for any guidance.
7 REPLIES 7
Erwin Edel
You could try using a 3D document, maybe. In axonometry use View > 3D Navigation Extras > Look To. This allows you to project the view straight on the selected surface. Right click in the view and pick New 3D document From 3D...
You can set up this view just like a section or elevation and should be able to add dimensions to it.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Thank you Erwin, your advice and steps were really helpful/easy to follow.
I created the 3D document from the view (first image) and tested the dimensions. I just had some queries about the dimensions and how to obtain one along the splay (second image) as it seems to constrain it to either 90 degrees or an odd angle?
MrC
DIMENSION OPTIONS
ILIFFE ARCHITECTURAL
BRITISH COLUMBIA
macbook pro 2.7 GHz Intel Core i7 8 GB 1600 MHz DDR3 NVIDIA GeForce GT 650M 1024 MB
AC 21 USA (latest build)
Thanks, still coming out a bit funky! Not sure why the angle dimension is greyed out too
Erwin Edel
There might be some limitations to dimensioning in 3D document. If you don't mind it being static dimensions, you could make them static or dimension to a hotspot that you can move around.
Or explode the whole view to 2D fills.
www.leloup.nl
Windows 10 Pro
David Maudlin
thompsonmp:
In the 3D Document there is an additional dimensioning option for plane constraint, in the Help files see: Linear Dimensions in the 3D Document Window.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you for everyone's replies, much appreciated.
Constraining dimensions to planes should be a big help thanks.
