2018-04-2503:38 PM - last edited on 2023-05-1801:27 PM by Gordana Radonic
2018-04-2503:38 PM
Hi
I'd appreciate some help on how to created a reflected ceiling plan of a sloping soffit. I've not done any RCP's in Archicad yet and what I would also like to generate are plans of the sloping soffit looking square on in order to create cutting layouts.
You could try using a 3D document, maybe. In axonometry use View > 3D Navigation Extras > Look To. This allows you to project the view straight on the selected surface. Right click in the view and pick New 3D document From 3D...
You can set up this view just like a section or elevation and should be able to add dimensions to it.
Thank you Erwin, your advice and steps were really helpful/easy to follow.
I created the 3D document from the view (first image) and tested the dimensions. I just had some queries about the dimensions and how to obtain one along the splay (second image) as it seems to constrain it to either 90 degrees or an odd angle?
There might be some limitations to dimensioning in 3D document. If you don't mind it being static dimensions, you could make them static or dimension to a hotspot that you can move around.
