Friday
hi, opened new file of archicad and all furniture is showing with minimal space. Yes, there is option to change it Manually at every-single time when placing the furniture but I know there was option to remove it automatically.
I went to model options > Miscellaneous settings > library parts - archicad legacy objects (doors/windows) ALLOW removing the minimal space. However library parts - the furniture , does not show this option.
I could not find it in the screen view option neither.
older files are ok... I guess I forgot how I turned it off 😄 .. Could someone help?
Solved! Go to Solution.
Friday
uffff nevermind. there was a tiny check option in model views I did not see.
Friday
