cocoloco
Removing minimum space at object
hi, opened new file of archicad and all furniture is showing with minimal space. Yes, there is option to change it Manually at every-single time when placing the furniture but I know there was option to remove it automatically.
I went to model options > Miscellaneous settings > library parts - archicad legacy objects (doors/windows) ALLOW removing the minimal space. However library parts - the furniture , does not show this option.
I could not find it in the screen view option neither.
older files are ok... I guess I forgot how I turned it off 😄 .. Could someone help?
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
1 Solution
cocoloco
uffff nevermind. there was a tiny check option in model views I did not see.
Go to post
cocoloco
