Renovation - Demo Filter and Labels
I have noticed that, and it is enormously frustrating, when using the reno filter for demolition plans all is well until I switch to my layout when the saved view is placed as a drawing.
In my floor plan view (working space) where the PROPOSED doors and windows are going to be in my EXISTING walls appear as the overridden dashed lines and fills, the properties of the wall. This demonstrates that there is a wall here and the builder is to create an opening. All is well.
When I switch to my layout the previous occurs but also the PROPOSED dimension marker which is associated with the door or window is appearing as well. This should not occur. It does not appear in my saved view (working space) only in my placed drawing. Considerably annoying.
Does any one know why this occurs or how to fix it?
Is it possible to write script into the dimension marker to prevent this?
If this is a bug it needs to be fixed ASAP.
If it is intentional there needs to be an override ASAP as we are currently resorting to the dreaded...2D fills...aarrrgghhh!!!!
0 Replies 0
