Barry,
Similar thoughts but as you can’t have a window/door without first forming the opening, I would prefer it if the window/door object was associated with/attached to the opening instead i.e opening tool becomes the primary tool with window/door as option. Ideally…
- Place opening in wall using enhanced (custom shape, lintel option, cavity closers option, display on home story only, invisible fill option to boundary instead of inherit from wall) opening tool
- Add standard Archicad window/door object to opening i.e. no longer associated to wall but associated with opening instead. Move the opening, the window/door/lintel/cavity closers move with it etc
- Following issue of basic window/door schedule, the ability to replace the standard window/door object with specific object provided by preferred window/door manufacturer showing correct structure/detail etc
Ling,
I normally only use one opening per window/door & highlighting demolished elements hasn’t been a problem (so far) although I vaguely remember having to play around/fine tune the opening/renovation settings to get this to work the way I wanted it.
In the images you provided…
- are you saying that the window should be showing but it can’t be seen (in the layout or 3D) due to the empty fill of the opening?
- can you explain further how you’ve setup this configuration up e.g. window (with or without opening?) set as To Be Demolished?; with new opening (same size or larger than existing?) set as Proposed?; new window set as Proposed?
- can you show how you’d (ideally) want it to look?
AC16-28 Solo (latest version)
OSX 15.2 - MacBook Pro 16" 2.4 GHz 8-Core Intel Core i9 - 64Gb DDR4 - AMD Radeon Pro 5500M 8 GB
