Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Renovation filter, dimension labels, zone stamp
Hey,
When using renovation filters and checking the box "Do Not Override Dimension/Text/Labels" some labels still are overridden.
The text labels display perfectly, but if they are changed to Dimension 17 then suddenly they are overridden by the renovation filter...
Also, is there a way to protect Zone stamps?
Thanks
1 REPLY 1
Stuart Smith
Just checked 18 and get the same result.
Can't find a work-around, other than not using labels on demo plans.
ATTN: Graphisoft! It would be great if labels other than the default "Text" label were not overridden. We're using keyed notes (just a number in a circle), and it looks really strange to have the circle be a dashed line.
AC user since 8.1
