Resolution dropoff when printing from AC10 to HP 1055 CM
We are having problems when printing from AC10 (Mactel 1188) to a HP1055 CM using the print command. The resolution on our printouts is dropping off in portions of the printout, while in other portions the resolution is just fine. This is affecting fills and lineweights, where parts of the drawing are crisp and legible while others are fuzzy and faded. Our initial thought was that the plotter was the problem, but after a session with our plotter technician and installing new drivers, the problem persists. Has anyone else experienced this, and if so what can we do to fix the problem?
Djordje
How much memory does your HP have?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
128 MB, which is the most memory the plotter can accommodate to the best of my knowledge.
