jrmrt
Restructure Schedule to Fit Layout - can you set margins/offset?
Hello Documentation Forum,
I was experimenting with the 'Restructure Schedule to Fit Layout' command, and stumbled on something that I can't find an answer to.  If you have a schedule that is oriented by columns, like in a visual door or window schedule, when you restructure the schedule it leaves a gap/margin between each of the split schedules.
However, if the schedule is oriented by rows, when you restructure the schedule there is no gap/margin between the split schedules.
Is there a way to set what that margin/offset/gap can be so that the a schedule oriented in rows doesn't look like it's glued on the adjacent schedule?
Thank you!
Operating system used: Mac Apple Silicon 12 Monterey
0 Replies 0
