Revision and Delta in the project
Hi!
I have a question:
Which is the best way to manage the delta and the revision clouds in the project?
It's better on the layout or on the model?
Thanks
4 Replies 4
yes, it is crazy GS have not addressed this in all 13 versions of the software!
CADIMAGE have an addon if you have the money, but it has its own issues...
Personally I would say definitely use the layout to note revisions. If you do it in the model you need to update view definitions with each revision. It quickly becomes very painful.
Thanks.
You are absolutely right.
Maybe GS is perfect and doesn't need revisions!
vfrontiers
Only trouble I've experienced is if you end up moving the drawing on the Layout and forgetting to move the REV BUBBLES with it. I presume you can group them together.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
The real problem is that GS hasn't addressed this major flaw and common issue for the revision on C.D.
